Panasonic G20 / Harman Kardon SB 16
Forum Name: Plasma TV
URL: https://forum.recordere.dk/forum_posts.asp?TID=120217
Printed Date: 23-Maj-2025 at 19:26
Topic: Panasonic G20 / Harman Kardon SB 16
Posted By: moose74
Subject: Panasonic G20 / Harman Kardon SB 16
Date Posted: 10-Februar-2013 at 20:11
Har mig en Panasonic G20, og modtager på tirsdag min soundbar harman Kardon SB16, mit spørgsmål går ud på, at min svigerfar har fået sig en samsung smart tv + SB 15 soundbar, og hans tv lyd kan slåes helt fra, så soundbaren`s lyd kun bruges.
Kan man også dette på panasonic g20 modelen ?, altså skru helt ned/slå lyden helt fra, og kun have lyden fra soundbaren.
Bonus info : Der er ingen remote med til SB16, TV`ets Remote bruges som Volume op/ned
tvix rocks !
Posted By: Bruger udmeldt 43
Date Posted: 10-Februar-2013 at 22:14
Ja, der er en mute knap som lukker for lyden i TV højttalerne. Og der kommer stadigvæk lyd ud til en soundbar via optisk/coax kabel
Posted By: moose74
Date Posted: 10-Februar-2013 at 22:25
Okay, men bruger jo tvèts remote, og når jeg skruer op og ned, vil MUTE så ikke slå fra ?...
Har fundet disse link, der gør mig meget i tvivl om det er SB16 jeg skal have.
Quote:
Originally Posted by Laron  http://www.avsforum.com/forum/post/18275730">View Post
Is there an option to permanently turn off the TV's built-in speakers? For instance, I want to connect a soundbar to the TV's audio out and program the TV's remote to control the soundbar's volume. I don't want the volume control adjusting both the TV's volume and the soundbar's volume simultaneously.
Yes you can turn the TV's internal speakers off in the audio menu.
However, the TV's Optical Audio Output is fixed/line-level; the TV's remote doesn't control the volume level of this output so when you say you want to "program the TV's remote to control the soundbar's volume" i hope you mean you have an aftermarket programmable remote and won't be using the Panasonic remote. If you use a sound bar with a Panasonic, you have to use the sound bar's remote to control the volume. And FWIW, the G20/G25 don't have an Analog Audio Output - it just has Optical.
http://reviews.cnet.com/surround-speaker-systems/harman-kardon-sb-16/4505-7868_7-34482357.html - Harman/Kardon SB 16 Review - Watch CNET's Video Review
tvix rocks !
Date Posted: 10-Februar-2013 at 22:27
Ja du skal anvende en "multi-remote"
Posted By: moose74
Date Posted: 11-Februar-2013 at 07:32
Planen var jo at bruge G20 `s Remote som kan instilles til soundbaren....
har læst noget om hotel mode i panasonics tv, kan man mulighvis slå højttalerne fra der....?
tvix rocks !
Posted By: moose74
Date Posted: 17-Februar-2013 at 20:15
Mit G20 remote kan godt bruges til at skrue op/ned på min JBL soundbar......men skal først i vieraLink hvor der er 2 muligheder : TV Højttaler eller Biograf.
Vælger jeg biograf, virker volumen på tvéts Remote til soundbaren, men slukker jeg tvèt, og tænder igen, er den sprunget tilbage til TV højttaler .....? nogen der ved hvorfor, og hvordan for jeg den til at blive på biograf.
tvix rocks !
