MsFrederiksen wrote:
Hejsa Alle jeg vil høre om du kender en dansk guide med gode instilinger af billede i spil film sport
M.v.h Martin
På forhånd tak.
Hej Martin og velkommen til recordere.dk
Den eneste jeg kender er fra engelse AV forum, men ret nem at gå til. Kan du bruge den?
Hvis du kan så følg slavisk denne:
For SKY HD, PS3, Blue Ray or HD/DVD (BLUE RAY, PS3 OR HD/DVD YOU NEED TO ADJUST PURE CINEMA) (SKY HD SET PURE CINEMA TO OFF)
AV SELECTION ***MOVIE***
CONTRAST 30 BRIGHTNESS 0 COLOUR -2 TINT +2 Towards Green SHARPNESS -15
PRO ADJUST > PURE CINEMA FILM MODE OFF &am p;nb sp; (BLUE RAY/HD DVD Smooth or Advanced) TEXT OPTIMISATION OFF &am p;nb sp;
INTELIGENT MODE OFF
PICTURE DETAIL DRE OFF (Low if you prefer) BLACK LEVEL OFF ACL OFF ENHANCER MODE 2 (1 if you prefer) GAMMA 2
COLOUR DETAIL MANUAL (HOLD ENTER FOR 3 SECS) COLOUR TEMP R High -2 G High 0 B High +2 R Low -1 G Low 0 B Low -1 CTI OFF COLOUR MANAGEMENT R 0 Y 0 G 0 c 0 B 0 M -7
COLOUR SPACE 1
If you're using a PS3 via HDMI with this TV, there is a bug that will destroy shadow and highlight details if you have "RGB Full Range" enabled in the PS3's display settings. I won't go into the technical details as to why, but to set up your PS3 properly with this TV, you should go to:
1: Settings > Display Settings > RGB Full Range (HDMI) set it to "Full"
2: Settings > BD/DVD Settings > BD/DVD Video Output Format (HDMI) and change it to "RGB"
3: TV Menu > Option > HDMI Input > Video and change it from "Auto" to "Colour-4"
After a second or two, you should see the image change to a lower contrast, and far more accurate image.
NOISE REDUCTION Field NR OFF All others OFF
OTHERS IP MODE 1
