Panasonic TX-P50VT20 brightness problem
Forum Name: Plasma TV
URL: https://forum.recordere.dk/forum_posts.asp?TID=91265
Printed Date: 07-Juni-2025 at 12:00
Topic: Panasonic TX-P50VT20 brightness problem
Posted By: dr gonzo
Subject: Panasonic TX-P50VT20 brightness problem
Date Posted: 05-Januar-2011 at 01:35
Jeg købte lige inden jul dette fantastiske tv og jeg er ret begejstret for det. Men jeg har et problem med automatisk brightness.
Jeg bruger THX-indstillingen og ECO er slået fra. Problemmet ses, eksempelvis hvis skærmen er helt sort, men der er undertekster. Ca. et sekundt efter at underteksterne forsvinder, er det som om at tv'et kompenserer for den manglende lys på skærmen, og skruer en tandt op for brightness, den sorte skærm bliver lige en lille smulle lysere.
Det sker også i mørke scener, og her er det meget belastende, da jeg ikke kan undgå at se det, og derfor bliver revet ud af filmens univers.
Jeg har fundet en enkelt på nettet som beskriver det samme problem:
"I recently purchased a 50" Panasonic VT20EA. It's a sweet TV all-in-all, but something bothers me.
So far I've used it mostly for gaming (PS3) and during darker levels I can see the TV switching brightness to somehow match the scenery. I use the TV in a colour calibrated THX mode, Eco mode is turned off and room lighting is consistent.
Case in point would be Uncharted 2. When I press Start, the screen goes darker to show the menu and my TV compenates by inching the brightness up by a few visible notches (within a second or so). The brightness toggle stays put but I can clearly see the difference. When I bring up the in-game XMB with the PS button the brightness goes down a notch again, as the XMB icons seem to have quite a lot of brightness to them.
What could be the cause to this and can I stop my TV from doing it?"
Men det er ikke lykkedes mig at finde en løsning på problemet. Er det noget nogen af jer har oplevet? Og er der nogen der ved om det kan slås fra?
Posted By: dr gonzo
Date Posted: 06-Januar-2011 at 22:25
Jeg har nu, efter at ha' researched lidt mere, fundet ud af at der er tale om det man kalde Floating Black, og at det ikke kan slås det fra :(
Denne skærm er mit første TV i 7 år, jeg har altid sværget til Projektor, og da jeg aldrig ser TV, har jeg ikke set nogen grund til at eje et TV apparat. Men Nu ville konen gerne ha' et, så jeg valgte at købe det apparat, jeg efter at ha' læst en del anmeldelse, troede var det bedste man kan få. Men Floating Black pisser mig virkeligt af... det ødelægger totalt min oplevelse.
Er der nogen der kender nogle gode settings, som kan minimere problemet? For det kan da ikke passe at der ikke er andre herinde, som det generer. På AVSforum har jeg kun været i stand til at finde forslag som matcher de amerikanske udgaver af apparatet, men da menuerne derover er anderledes, kan jeg ikke bruger deres indstillinger til noget.
Hvis ikke jeg finde en bedre settings som afhjælper problemet, bliver tv'et sku solgt.
Jeg synes at det er under alt kritik at Panasonic ikke giver folk mulighed for at slå den feature fra, hvordan kan de tro at folk der køber tv i denne prisklasse, ikke vil føle sig generet af den skiftende brightness? Jeg føler mig totalt taget ved røven og desværre kan jeg ikke levere apparatet tilbage.
Posted By: .FTH'
Date Posted: 06-Januar-2011 at 22:30
Du er ikke alene om den oplevelse, desværre!
Jeg oplever det selv af og til ... Confused
JVC - Quality Screen - XTZ - ONKYO - Parasound - PS3
